Hi Nik, Yes, it all worked flawlessly but the resulting files have zero content. Here’s the before and after files as a single zip (it may take a moment for them to upload to dropbox): https://dl.dropboxusercontent.com/u/3962425/Teaching-15-16-SCM-01.zip
Sure, will try and report back to you.
Hey I am editing my post to say that I got my problem solved, and actually, it wasn’t RW fault at all. I just didn’t selected the Sidebar to be displayed at the Master Style Settings… Shame on me and sorry to bother you!!!
Latest beta build working perfectly fine for me. No errors so far.
Thank you.
Nik
Not sure what the old version was. The link for the upgrade was already checked by me before the install of the new version. There’s nothing relevant or helpful to this problem in it (I have no plug-ins etc). Could you check the files I put on dropbox when you get a chance please (https://dl.dropboxusercontent.com/u/3962425/Teaching-15-16-SCM-01.zip)?
Looking at the project, your RWSW file was not saved with RW5.4.1, as required in the upgrade guide. Please follow that step once more and then open the RWSW with RW6!
http://realmacsoftware.com/rapidweaver/upgrade
—N
OK - I should RTfM I guess - thanks. Will let you know outcome
Yep, it worked - thanks
@nikf
In RW 6.3.5 there is a little bug in the Snippet Box.
I can no longer read the code, when it’s a long code and the window small. The text is pushed together.
I must/can enlarge the window, then I can read the content of the snippet.
In RW 6.3.4 it worked fine.
Hello, after installing RW6.3.5 beta 15089, 15097 and 15114 I still get BLACK thumbnails in the Photo Album, It’s somehow related to the size of the image: if it’s 6016x4000 (all images are in Fotos App) the thumbnails are black. If the size is smaller the thumbnails are OK. The detail picture is always OK .
Preview
KR Bernd
