🐞 RapidWeaver 7.5 Beta
We’ve been working on RapidWeaver 7.5 for some time now, and while we’re not yet finished with it we wanted to get it into your hands as soon as possible for testing.
Our plan is to release the final build of 7.5 when High Seirra launches later this year. As 10.13 is still being developed we’re keepign an eye on it and will do our best to make sure RapidWeaver is compatible with it on day one.
Read the full blgo post here: http://blog.realmacsoftware.com/rapidweaver-7-5-beta/
What’s New (so far):
  • Added Automatic FTP Configuration
  • Media Browser works again!
  • Added a preference to verify uploaded files
  • Other minor bug fixes
As this build is a beta (albeit a stable one), you are advised to back-up your projects before use and not to use this build against mission criticle work.
Download RapidWeaver 7.5 (build 18737) Beta
Happy Weaving and do let us know if you hit any issues!
Can’t publish, just as bad as 7.4.1 :frowning: Going back to 7.4 :slight_smile:
Oh, and the “send feedback” e-mail server is apparently rejecting e-mails :slight_smile:
Try emailing support@realmacsoftware.com with as much info as you can
Big request, please disable (or turn off) the project autosaving when exporting it! It is very uncomfortable. Though in this version do it. Who and what for at all has thought up to enable an autosave without the demand of the user?
I do not know, as in the seventh version, but in the sixth with this problems like would not exist. In RW 7, sometimes you have to save a project with a different name and publish this project already (because even canceling, or Undo, actions/changes does not always work clearly).
7.4.1/7.5b publishing is now sorted out, man is the publishing fast! Well done @dan & co. :joy:
Glad to hear it’s working for you :+1:
