The update did work just fine for me. But I didn’t use the dmg-file behind the link in Dans post but the normal update mechanism when launching RW and it then detects that an update is available…
I had no trouble updating from within RW8
All software and equipment current.
When I publish, the publishing dropdown info window does not close after publishing.
The only button or menu that works is the logs? button and that says “no logs…”
I have tried to click on any menu item or button to try to escape the drop down without success Therefore I force quit.
Cheers Marty
PS I am still wanting to know what “application call back error” means.
All my projects lost resources with this update - hours of work. Many resources showing as being ‘External’ which they are not. Also found that ‘Resolve’ option worked for some but not others and the quickest way was to relink from the resources window.
Crumbs. That sounds pretty bad. I suppose I’ll give it a whirl with one project and see how I get on. Gulp. Wish upgrading didn’t always feel like such a leap of faith.
In reality it’s only an issue if you remove the published site and republish afresh - after all the old resources aren’t going anywhere on the server. Nevertheless the update has to be done if you want a fresh publish for any reason, and it is a nuisance having the warning pop up every time you open a project!
