Hey you lovely developers,
Here’s the final final final GM build of RapidWeaver 8.1 - We plan to go live with this on Wednesday 23rd. Take it for a spin and check compatibility with your plugins, stacks, and themes to make sure the launch goes smoothly
Download RapidWeaver 8.1 GM (Build 20579)
FYI: Going forward we plan to ship smaller, more frequent updates as this 8.1 release is a bit of a whopper.
And finally, thanks for all your help along the way, we really appreciate it.
Cheers
Dan
What’s New in RapidWeaver 8.1?
- Sandboxed!
- Dark Mode for Mojave now supported
- Added Amazon S3 as a Publishing Destination
- Touch Bar support added
- Added support for resizing the preview in the main window
- Added support back in for copying a resources URL
- Added a new drop down menu to the Simulator toolbar button
- Added iPhone XS Max to the simulator window
- Added an option to disable OpenGraph metatags on a per page basis
- Add a new preference to disable UI sounds
- Multiple selection is now supported in the Resources Browser
- Resources can now be dragged from a child folder to the root resources folder
- Source list layout is now restored between opens
- Improved the handling of files in the Resources Manager
- Files in the Resources Browser can now be renamed
- Fixed an issue where the sitemap plugin and sitemap.xml was displayed and exported incorrectly
- Fixed an issue with adding edited photos from the resources browser
- Fixed an issue with resources not getting exported when previewing
- Fixed an issue where RapidWeaver would appear to deadlock while opening projects
- Fixed an issue where RapidWeaver would re-publish all files on every publish
- Fixed an issue where RapidWeaver would get stuck looping between pages
- Fixed an issue where the incorrect path would be used for social tags in the page header
- Fixed an issue with multiple buy buttons showing
- Removed the javascript that was removing line breaks from the Offroad theme
- Fixed an issue where banner images wouldn’t show due to an issue with CSS consolidation
- Fixed a naming issue with FontAwesome
- Show Properties button in Blog now works correctly
- Fixed various podcasting and channel issues within the Blog page
- Fixed an issue with page styles being incorrectly applied to Master Styles
- Fixed up an issue with the Addons Installer
- Fixed up various crashes in the Photo Album Plugin
- Fixed a crash when using “Reveal in Finder” and the resource cannot be found
- Fixed up crash when using the link panel
- Fixed a crash that would sometimes occur in the Snippets Window
- Plugin information is now logged in crash reports
- Numerous other fixes and enhancements!
