Please could someone kindly remind me where the Stacks folder in RW6 is located.
Richard
Richard
Hi @richardmaps!
Within Rapidweaver… Hold down the Option key and choose Reveal Addons Folder from the View menu.
The Reveal Addons Folder item will only appear in the menu when you are holding down the Option key.
Also… here is the path that will open up for you:
~/Library/Containers/com.realmacsoftware.rapidweaver6/Data/Library/Application Support/RapidWeaver
Richard,
Alternatively, you can also always just right-click a stack and choose: “show in Finder”.
You can also hold down command & option and hit the 7 key while in RapidWeaver and it will open the folder for you too.
Many thanks to all you guys for that quick response. I think I was about halfway down that long route to the Stacks folder before your kind guidance. Have arrived now.
Richard
