While I was building a few pages, I ended up modilfing 40 images 5 or 6 times over, with size and resolution changes.
After finishing the pages, and Publishing out to a local folder, I now find I have hundreds of images that are not even used in the pages anymore.
I checked the ‘Resources’ folder in RW, and sure enough, there they are, all 300 of them.
Is there a right way to delete them?
Where the ‘don’t send unconnected resources’ check-box? somewhere that I can’t find?
So for now I figure I would manually delete them… buy I can’'t seem to sort them by date,
or know the best way of deleting them? Multi-select? Sort? Something else?
No Date view, No list view, No unused view?
How do you guys handle it?
Thank You
