Replacement for RapidAlbum?
Hey all,
I’m in the process of reviving an old site that’s been offline for 3 years.
It had about 13 photo albums created using the RapidAlbum plug-in. However, I note this plug-in has been abandoned and is not working in versions of RW past 5.x.
What would be the closest replacement to this plug-in?
I want to be able to point to a folder (a directory on the server would be preferable but local would do as a last resort) and have it do the rest with all the photos in each. Adding photos manually is not workable as there are around 100 photos in each album. I know there is the built-in Photo Album plug-in but was hoping for something just a bit more flexible if possible. :wink:
Thanks!
John
You could try this https://nickcatesdesign.com/preview/rapidweaver/photo/
if your a stacks user
Have a look at the Gallery Stack from www.instacks.com
And one more to consider - https://stacks4stacks.com/progallery/
  • it’s available as a demo as well so you can check it out before purchase.
