Just upgraded to RW 7. Opened RW 6 site, made some changes. Publishing fails with same settings as RW 6. Reopen site, test connection: Pass. Open site in RW 7, test connection: Fail, using the ame settings.
Any thoughts?
Any thoughts?
Check that your password is taken over correctly.
Also check the host name and folder where the content should be published too.
In Publishing Setup change the mode to Extended Passive.
Worked a treat. Thankj you, Sir!
G
