Where can I find the folder of RW8 Themes on my mac?
They are kept in the app itself, not something I would go looking for though if I were you.
You can copy them in the theme window(right click). The copy is stored in the addon folder. Then right click the copy and show in finder.
Thanks for explaining. I thought I could modify the themes as in the older versions.
You can modify the copy, older or newer.
Hey, thanks so much. I got it.
