What does RW backup on server contains? It is the same project file on your local computer in same size or does it contain more in it? If same then we just download it and open it like a normal project file?
It’s a publishing setting. SO backups will happen when you publish, at the frequency you specify. But if you don’t publish, no backup. It’s not likeTimeMachine that backup when you change. I don’t use it, I have plenty of backups going on(off-site and TimeMachine), tested it and it seems to work ok.
I had to cycle a setting in a page to get the publish button active then I could publish a backup on the sites that I already published in the past without the backups.
I think developer should add a feature that if the backup setting was changed in publishing setup then the publish button should be active to allow them to back up websites that they already published in the past.
