RW Publishing when using Cloudflare
Hi
I’m using RW Version 7.5.5 (18814), I’ve enabled Cloudflare on the site, SSL option is turned on and I have https working.
I have a subdomain setup that, that already has a site published to it, that I’m trying to update/publish to from Rapidweaver. When I do I get an “offline” error, as if my username/password is wrong.
I can sign in using Forklift as an ftp client, with the same sign in credentials.
If I ‘pause’ Cloudflare publishing from RW works again.
I’ve tried setting Cloudflare to bypass ftp, but that hasn’t worked.
If anyone has had a similar experience or can provide some pointers to help me resolve I’d appreciate it.
Many thanks
Regards
Mark
You cannot FTP into a subdomain that is managed through Cloudflare. You need to setup another alias inside CF that is disabled.
