OK Hopefully someone will be able to help. For the life of me I cannot figure out why my code keeps breaking when I add things to the side bar on my theme in RW5.
Please don’t tell me to upgrade. I have RW6 and I cannot customize themes and the like with it. It just does not work for me. This site was built with 5 and I’m just trying to add simple code. I"m going to use a screenshot of the sidebar code so you can see where it breaks. It’s the two codes 2nd & 3rd from the bottom. Is there something I can’t see ?
I manually uploaded the files to the /resources directory too.
Permissions are fine.
Cleared cache.
Side bar setting is HTML. I tried using styled text and it still fails.
Before I go and put it on all the pages I need to see where I’m breaking the code.
site url: http://versailleskennels.com
and here is the actual code:
[/code]
