This seems to have started after installing Joe Workman Target stacks. Not sure if it is related. When ever I publish my website RW shuts down.
Don’t know what the problem might be.
I just tested Target, and it publishes fine for me.
Might be one to report to RealMac Support.
Thank you
looks like a Stacks problem. What version of Stacks are you using?
Hi from germany. Updated to Big Sur last night, since then I have problems with publishing an existing page (just made a simple change) --> RW crushes. Starting over again --> crushes.
Next I started a simple new project, entered all publishing details, tested the entered details and the publishing worked superfine!
So I got back to my main and important project, entered a second destination (“Add new destination”), deleted the first one - saved - and of course it crushes immediately when trying to publish.
What can I do? Thank you in advance and sorry for my english…cheers, elch26 (BIG SUR & RW 8.7)
Target 2.0.6
Sorry 4.1.0
Please try installing Stacks 4.1.2. It fixed a number of crashes similar to the one your crashlog describes.
I would also recommend disabling plugins that you are not using currently.
Since there have been a lot of updates: RW 8.7, Stacks 4.1, Big Sur, etc. – it makes things easier to diagnose, when there are fewer moving parts. Removing unused plugins is a good place to start.
Open the RW Preferences
Choose the last tab: Addons
Disable things in the Plugins category that you’re not currently using.
Then restart RapidWeaver
Isaiah
Yes the version 4.1.2 of stacks fixed my problem. Thank you
