Is SEO-Rx still compatible with the latest version (8) of Rapidweaver?
@barchard
I’m not 100% on that, but be sure to disable generate social tags in Settings > General!
Yes absolutely
as long as Stacks is compatible then SEO-Rx is compatible.
Greg
SEO-Rx seems to work fine for me in RW8
@Aaron a bit off subject, but why would you disable generate social tags? Is there a link that explains all the checkbox options settings?
Because RapidWeaver generates social tags by default, disabling means the stack/plugin will have full control over what’s inputted. It’s a precaution.
SEO-Rx reports it’s findings to the user. It does not modify/add/alter content. Therefore, turning this off would not be recommended.
