Sidebar is NOT showing - Altitude theme
The sidebar content is NOT showing on ANY of my pages, except the ones with a FormLoom 3 form! Very strange!
I am using PlusKit to bring a stacks page, sb, to the sidebar using the command @import((sb)) in the sidebar, where sb is the stacks page that contains my content. In the formloom pages, of course, I use the Formloom remote add-on instead. In the formloom pages, the sidebar does show! Weird!
The sidebar content, brought in with PlusKit, does show up in Rapidweaver, but not on the published pages, except on the ones that utilize the formloom forms.
The above sites were both built using the Altitude theme, and are basically identical except for content.
Anyone?
Hmm I have re built all my sites that I had used pluskit years ago due to that fact that it was not being maintained and requires rosetta now. there maybe a reason as to what and why pluskit is not working maybe a conflict somewhere. looking at your site
seems to be some resources are getting 404 error
your form page has even more errors
Thank you for taking the time to reply. What do you use instead of PlusKit?
Do you have any idea how to get rid of all these errors?
Rebuilt the sites using Foundry frame work Stacks and the forms are now in formsnap. I still have one site left in a theme that needs finishing up but also removed pluskit and Sitemap plugins and moved the content to stacks.
Is Foundry even available anymore? It seems everything I used or am being suggested to use has been either deprecated or canceled.
Hi @andreasfmpro,
No, Foundry is no longer available or supported. Its publisher (Elixir Graphics) closed down last year rather suddenly.
If you already own Foundry, you can continue to use it as it still works fine with all modern browsers. But there won’t be any updates down the line I’m afraid.
For support, your best option is to simply ask here, on these forums, as there are quite a few (pro) Foundry users in this community.
The documentation has been removed from the publisher’s website too, but can still (largely anyway) be found on the Wayback Machine (here for Foundry 2, and here for Foundry 3).
Sorry to be the bearer of bad news!
Erwin
I never used Foundry, but scottsteven suggested it.
