I have used sitemap plus for years, it’s excellent, now I am on the latest version of RW, and my sitemap plus (latest version thanks Isaac) is well placed in the add-on folder, but it does not appear in the library, so I cannot set up a new page sitemap. I reinstalled the plugin, I restarted rapid weaver, nothing working
any idea out there?
Hello Douglas, I have already checked that, the plug in is in the your head folder, but does not appear in the library, so I cannot create a new page with this stack on; I went to another website that I disd a while ago, this website has a sitemap plus page that is functioning perfectly well, but although the page exist, and the plug in is working, it stil does not appear in the library
I am really baffled, may be Isaiah will have an answer?
PJ
Sorry I did not realise I put a space, it is in the “YourHead folder”, there are a number of folders created with the name of the author of the plug in
It is bizarre, on the other website, I checked that everything was working, including the registration; it is all ok, but the plug in is not visible in the library
Sitemap Plus is an add-on not a stack. If you’re looking for it in the Stacks library, you won’t find it. You need to add a new page and select Sitemap Plus as the page type.
