thanks forum admin guys.
I am a member of Dooboxâs slack channel, so when I click on the link for yourheadâs slack channel, I donât get offered the opportunity to âget my inviteâ, I just get the password field. I have paid for the upgrade to Stacks 4 and am very happy with it, although there seems to be a small unexpected feature that I am âenjoyingâ (It may well be some sort of interaction with another app), which might have been discovered already. Any chance of an invite @isaiah so I can check? Thanks
Iâm members of probably a dozen Slack Channels and if I put in this URL:
http://slack.yourhead.com
I still get the email page above.
This URL asks for login:
https://yourhead.slack.com/
Note slack and yourhead are in different order.
To get an invitation to the YourHead Slack channel just visit this address:
http://slack.yourhead.com/
After you enter your email address, youâll be sent an invitation. If that doesnât work for whatever reason (it should â several people joined today successfully), but if it doesnât, just send me your email address in a private message here or via Twitter DM or whatever and Iâll send you an invitation manually.
Then watch your email â it usually only takes a few seconds â and make sure to check your spam folder does not accidentally eat up your invitation.
Isaiah
Thanks. That worked and I registered. I see that my unexpected feature has been discovered, so I can get on with learning about the intended features now!
I have 3 Macs. If I purchase Stacks 4, can I install it on all of them?
The license for Stacks (and all of our software) is per-user, not per-machine. So long as youâre the only person using these machines, then one license is sufficient.
If youâre not the only person then youâll need to buy a license for each person using Stacks simultaneously.
Itâs just me using them, so Iâm good. Thanks.
Sorry folks but just to clarify; I bought Stacks 3 on 1st June and have just downloaded the beta to 4. Iâve installed it and I get the banner. However am I best waiting until the final release to see if I qualify for a free update? And if so, can I use the beta in the meantime or is it best to uninstall it and waitâŚ
Thanks muchly
R
The Stacks beta has almost** no limits â even when the âUpgrade Stacksâ banner is showing. This is to allow people to try out the beta and see if they like it and if it will be useful in their projects.
So feel free to give it a try. It should work great even though you donât have a Stacks 4 license just yet.
** There are a couple limits in the beta. It prevents publishing on very large projects. Using beta software of any kind on a large professional work of any kind seems unwise.
Thanks Isaiah, Iâll press on then⌠Iâm only trying it on small sites⌠Iâm very new to this Stacks malarkey but its totally changed the way I work and Iâm loving it! Converting many old sites now.
Cheers
Thatâs great! Iâm really glad youâre enjoying it!
To be honest, even with large sites things are looking very solid now for Stacks 4. We have only a handful of remaining issues â and some compatibility with older OS versions to iron out. Iâm hoping to be at âfinal candidateâ sometime next week.
Then Iâm going to take a few days off to take a deep breath before the release.
Isaiah
@Isaiah - Have been using Stacks 4 and RapidWeaver 8.3 for the Realmac website and everything is working perfectly
Nice job on Stacks 4 itâs
Edit: Question removed⌠Wrong threadâŚ
Hey How about this idea for Stacks 4 Beta⌠Why not create a system where you can send samples of the website to clients to look at as a mockup. This can be a all in one option within the stacks, instead of having issues to do so in other mediums⌠This can be a game changer
Publishing has nothing to do with Stacks. Itâs a RapidWeaver feature.
You can publish the website locally or on a server for the client to see.
Roger,
This is a beta version,
@isaiah on others have stated pretty clearly not to post questions or possible bugs on this forum.
Use the other channels posted above.
oops! Sorry⌠Too eager to get it working⌠Please disregard
Perhaps you could enlighten us as to how it can be done.
If i was a developer, I sure would at least try to get it done. But now i am design artist⌠so please u have the knowledge, Get to it and stop doubting yourself. Arenât you guys good at coding and solving problems? who why is it an issue to at least TRY
