I’ve just discovered that double-clicking on a new stack download to install it, -says- it’s been installed, but in fact, it is not. Unfortunately, this means dozens and dozens of recent updates failed, and I’ve now got to go back and check them all by hand.
you are dragging RW6 stacks to the RW icon on the dock, aren’t you?
No, as I explicitly stated, I was double-clicking the stack, and getting a message that says that the stack was successfully installed.
I take it double-clicking no longer works? If that’s the case, wouldn’t a better message be instructions on how to install, instead of a false message of success?
And yes, I’m using the stacks 3 updated, but not all stack support it yet. Developers are still working on that.
