…yes;-)
sounds surprising!
Does this happen if you use a different mouse?
@joeworkman
…yes checked - it seems it’s the MM - but no another one here - and this has grown together with my hand;-) Joke!
But when I use the MBPro Panel its seems ok.
So, at first I will check the Prefs from the Mouse - will come back later.
Best
Roger
@Roger - i’m sorry, roger i didn’t realize what you were showing me in that video at first. it’s only now come to my attention since other people were reporting similar things too.
for you this started right after installing all the updates?
can i ask: if you un-hide the Foundry stack. does the problem with random accidental reordering of things still happen?
i think it may be related to hiding Foundry (or other similar mega-style stacks like Foundation Site Styles). and i just wanted to test this theory.
Hi Isaiah,
yes, it happens after updating yours »filling horns« of gifts!
…and yes, after un-hiding the first level of Containers/Margins with others inside (as attached) it happens without a recognizable system!
And it seems - as @joeworkman mentioned, without my Apple MightyMouse its gone… It’s early one whit a lot of miles on my desk…
Best
Roger
I’ve released a beta version (Stacks v4.1.1b2) that should fix this issue. So long as there are no major issues with the beta, it will become the release version fairly quickly, probably 24 hours later.
The beta is public, but you can only get it on our Slack channel. And we appreciate if you only post about beta bugs or other beta things on the Slack channel too.
Sign Up: http://slack.yourhead.com
Sin In: http://yourhead.slack.com
Isaiah
