Thanks for the update with Checkout2 but what happened to the Custom amount?
It now only has Subscription or Fixed amount selectors.
I particularly require Custom amounts, I wish the removal of a very important feature had been advised in your upgrade notes before I went a spent $45 AUD on the update.
Great, thanks. Very good to hear Custom amounts will make a return.
Stripe payments is now working great…but…not on touch devices.
Well, the buttons are appearing on my iPhone but when I click on the button it doesn’t redirect to the Stripe payment page. It’s working lovely on the Mac but not on my iPhone…weird?
I’ve also tested with the Stripe code pasted into a html stack to create another button £95 item and same thing. Button appears but does not click through to the Stripe card entry page.
Hi Roberto, Thanks for the update. Do you know if we have to do anything on the Stripe website (see attached screenshot)? Or do we not need to worry about that?
@Lisa You can dismiss the message in the screenshot you attached. Just follow steps below to make your store compatible with new Stripe SCA requirements.
Enable Checkout method in Dashboard > Settings > Checkout settings on Stripe website.
Add your store domain URL in Dashboard > Settings > Checkout settings on Stripe website.
Copy Publishable key from Developers > API keys on Stripe website.
Paste it in Payments > Stripe panel in RapidCart Pro plugin.
So two things… Apologies for my ignorance… In the first step you listed, I don’t see anything that says ‘checkout method’, just ‘Checkout client integration’ (see attached screenshot). Is that what you mean?
Before I even completed the steps above, I got an email from a customer saying that the payment section wasn’t working. So I completed the steps as you directed above and then checked for myself and it is still not working.
When you get to the payment window, you press either Paypal or Credit card but nothing happens.
I haven’t added or done anything new to the store. I just did your update and these steps above.
@rob apologises for butting in on this thread, but I can’t seem to find a support email address and to save starting another thread… I wonder if you have plans and/or timescale for making RCP compatible with UIkit3 by @Lucas? Thanks.
File> Mark all Pages and resources as changed
File>Republish all files.
It is also sometimes an idea to delete all RW files from the server using FTP and then republish afresh, as old files will remain on the server even though deleted/over-written in RW. If you do this be careful not to delete files that live outside of RW such as the .htaccess file and any php files for CMS if you have any. To be sure, export your RW project to a local folder and use the folders there as a checklist
Thanks, have republished all files as per your instructions (thanks!) but still having the same issue. Am not confident enough to delete files for fear of accidents. I’ve been a Rapidweaver user for years now but am not a website person.
Hi, I have been having the exactly same problem as Lisa. I did everything written above, setting on Stripe account, deleting all files on server by FTP client, uploading by FTP (of course I tried publishing by RW as well). All I still see is a blank page where my customer type their credit information. Very odd thing is, the cart worked twice (out of 200 times during my test). I was even able to receive the payment in Stripe from my credit card. Next morning, It showed a blank page again. This happened twice. I am using RW7.5.7, RapidCart Pro 4.17, Stacks 4.0.3.
In debug mode, I get this: Notice : Undefined offset: 2 in /home/s2s99/public_html/rw_common/plugins/rapidcartpro/system/RCController.php on line 1180
Recoverable fatal error : Object of class stdClass could not be converted to string in /home/s2s99/public_html/rw_common/plugins/rapidcartpro/system/RCPayment.php on line 434
