I cannot get Total CMS blog to work an am beginning to suspect that it might be a PHP issue. Does anyone know if Total CMS works with PHP 8
In the TotalCMS updates section, there are references to using PHP 8. Joe actually recommends it. Total CMS Stack for RapidWeaver
Both Total CMS and Easy CMS a minimum of PHP 7.4+.
I run TCMS on PHP 8 with Chillidog as a host.
However, not all PHP 8 server installations are the same. A good test would be to try with PHP 7.4 and if it still doesn’t work, it’s probably your setup. If it does, then suspect the server PHP 8
Thanks … I will try 7.4
I switched to 7.4 and after some file permission issues I got it to work and then switched back to 8 and everything appears to be OK. Thanks
