Found these error logs on my server…
[25-Jul-2017 19:39:30 America/Chicago] PHP Fatal error: require_once(): Failed opening required ‘rw_common/plugins/stacks/total-cms/totalcms.php’ (include_path=’.:/opt/php71/lib/php’) in /home4/sparky/public_html/riksart.com/index.php on line 4
Sparky
swilliam
(scott williams)
26 July 2017 01:44
22
So just as a test, what happens if you preview the admin page I. RW and try to add text?
Are you sure all files republished? Looks like it can’t find one in the rw_common/…
It lets me add text. When I start typing on the box - a red square comes on around the text box
Thanks.
Sparky
swilliam
(scott williams)
26 July 2017 01:47
24
Red sq is normal, just means you need to save your edits.
If you save do you get green check?
Save button does not work in preview - but I expect that’s normal…?
swilliam
(scott williams)
26 July 2017 01:56
26
I think you can save txt maybe not photos cmd+S should save alsdo you get a red X
Yes - get the red x when saving text…
swilliam
(scott williams)
26 July 2017 01:58
28
Okay look at log again should be error from just a min ago
swilliam
(scott williams)
26 July 2017 01:59
29
If it is still missing file, I would republish ALL files from file menu
Interesting - no new error logs…???
Correct - still just the data from 2016…
swilliam
(scott williams)
26 July 2017 02:06
33
Edit mode or preview mode?
swilliam
(scott williams)
26 July 2017 02:08
34
You can also look in the cms folder on your server the cms.log file should be in there
In edit mode… Should I see something in preview mode with the debug stack?
You don’t think it’s the theme that’s causing all the grief?
swilliam
(scott williams)
26 July 2017 02:11
37
Could be but as far as I know it works with most themes.
Can you look at cms.log on server see if that error about not loading the cms PHP file happened again?
swilliam
(scott williams)
26 July 2017 02:13
38
You could always swap the theme temporarily just to see what happens, or save as so you have a copy and do it
Weird… no new errors or entries there either…
swilliam
(scott williams)
26 July 2017 02:16
40
That is weird, I would try a republish all from file menu, it acts like it is never even loading the cms code
