Re-publishing now…
and once again - nada… ;-(…
Sorry, I’m outa ideas , at least for now. You could try swapping the theme just to see, but I haven’t heard of any issues in that reguard.
I’m sure @zeebe can get you sorted if you open a ticket and give him access.
Just did that and am republishing again - deleted all the original files on the server first…
Republished with Foundation theme…
Warning: file_get_contents(http:www.riksart.comcms-data/cms.log): failed to open stream: No such file or directory in /home4/sparky/public_html/riksart.com/admin/index.php on line 194
See how it says www in the error is that what you have site URL set to in RW?
Is your site really http://www.ri… Or just http://ri… ?
Usually there is a warning if it’s incorrect but worth checking. Also make sure if your admin is at http://ri…/youradminpage you don’t access it at www.ri…
Seems weird there is a missing / in the error message
You might be on to something…
In RW publishing page:
Path is: /public_html/riksart.com
Web address is: http://www.riksart.com/
What is the actual site?
Most Cpanel will show you all that info, DocRoot etc.
I just compared it to my site - which works and does not have cms
The path name does not contain the .com - only the web address.
Have changed the path and am republishing…
Gett’n late here, I’ll check the thread in the am hopefully you will have it working.
If not @zeebe will get ya going
OK - thanks a bunch - really do appreciate your knowledge tonight…
Good Night…
Sparky
What did republishing do for you?!?
Made me get up and pour a drink while I regrouped… no luck
I get this as soon as I log into the admin page…
If I just add a regular Text stack - it works
Not sure why, but your cms-data folder is empty
http://www.riksart.com/cms-data/
Yes - I noticed that a few minutes ago as well - not experienced to know how to fix that…
Time for sleep…
Thanks to all who looked & tried to help tonight…
Sparky
Ready for Round 2…
Sparky
