Was presented with yet another update this morning, however, the update is not, er, ah, updating. I clicked update and it supposedly updated (it went through the motions) and after it was done automatically closed and restarted RW. But the update window appeared again and 7.1.4 is still RW’s version. I tried several times, but each time was identical to the last.
I also restarted my computer to see whether that made a difference but it didn’t.
Anyone else with this problem and any suggestions?
RW 7.1.5 has corrupted my project.
Now, I’m unable to publish our website. Has worked well this morning in 7.1.4.
If I go back to my backup from this morning, I’ll lose one day of work:imp:
I couldn’t open 7.1.4 after having the problem with the new upgrade 7.1.5. That really had me mad. I tried using time machine to go back to just before I installed the upgrade, but it was acting strangely as well. Restarted the computer twice. Finally got 7.1.4 to work again.
Can I replace the 7.1.5 (buggy with export) to replace by the 7.1.4 ?
If yes, does a project open correctly saved in 7.1.5 with the 7.1.4 ? (Otherwise, I’ll lost one of work)…
