I’m currently downloading the 6.3.2 version and I’m told to ‘Update Stacks’. Not quite sure how to do this? Help please.
Apologies, I meant ‘Blocks’. Which I have done.
With a Stacks page open to Edit, single-click on the Stacks Elements Library (small white cube at top left of content pane) icon.
From the Gear at the bottom right of the menu which this opens downwards, click on ‘Check for Updates Now’.
As each one appears - in the middle - accept its update.
Many thanks, @MarkSealey Off to a Stacks page I go. Cheers.
You’re welcome! Good luck…
Actually, Blocks is a plugin and not a stack so the stacks upgrader won’t do the trick. You should either get an update notice when starting Rapidweaver or, if that didn’t come up, you can download the latest version directly from http://yourhead.com/blocks/
You can also use the “Check for Updates” option in the main RapidWeaver menu to check for plugin updates as well as RW updates
I was going to ask the same question. Another thank you, this one from Hawaii. Aloha.
Thanks @LaPan Yes, I got the update notice when I started RW. All is good.
Cheers Brad
