Upgrade from 5 to 7
I have Rapid weaver 5 but need to upgrade to 7. If I upgrade can I transfer the website straight away without doing a lot of editing?
Hey Ann,
We have instructions on how to do it here:
https://help.realmacsoftware.com/support/solutions/articles/36000001229-upgrading-sites-to-rapidweaver-7/preview
Hope that helps!
Dan
Afraid link doesn’t work
Best wishes
Ann
Try this Anne.
https://help.realmacsoftware.com/support/solutions/articles/36000001229-upgrading-from-rapidweaver-5-rapidweaver-7
That’s fine. Do I have to pay to get this upgrade?
Ann
Yes, the update to RapidWeaver 7 will be a paid update. Any update from one version number to another will be paid, for example, 5 to 7. But if you had 7.0 and were updating to 7.5.5, then it would not be a paid update.
Beware. I am having nothing but massive problems related to the site Theme that RW7 cannot find and therefore I cannot open my RW5 project in RW7. I have not received any assistance with this problem other than for forum users telling me this is a known problem.
Mark, where did you get this ‘Geographic’ theme from? I’ve been knocking around the RW world since 3.5 and have never heard of it.
Rob
Downloaded rapid weaver 7 as instructed. no problem with that. How do I migrate them from 5 to 7?
Best wishes
Ann
I can’t open my projects in rw 7 and the article doesn’t say how to do it.
You need to be using RW 5.4.1. Do you have 5.4.1 installed?
Item 2 in the support article “Open your older project files (either with a .rwsw or .rwp extension) with RapidWeaver 5.4.1, and then save the project, to ensure it’s in a format that RapidWeaver 7 can read”
Have managed to do it thank you
Ann
