Upgrade to rapidweaver 7 from 5
I’ve just upgraded from Rapidweaver 5.3.1 to Rapidweaver 7, but I can’t open my website file. Error message is “The Cdf theme that this document uses is missing. If you open this project, RapidWeaver will apply the Affero Theme. Are you sure you still want to open this project ?”
If I clic on “Apply the & open”, the result is more or less nothing. What can I do ?
You may want to start again. There’s a fairly specific process for upgrading from RW5 (including making sure you have the latest version: 5.4.1). It’s outlined here:
https://help.realmacsoftware.com/support/solutions/articles/36000001229-upgrading-from-rapidweaver-5-rapidweaver-7
Thanks. I did it but when I open my file with 5.4.1 I can’t save my project. If I save it with a new name, nothing is saved either. Could you help me ?
I was away from RW for version 5 (I went from 4 to 6 to 7) so I don’t have any personal experience to offer beyond those instructions. If you haven’t done so already (and if no one else chimes in), you should drop a line to support@realmacsoftware.com and they should be able to get you sorted.
