Upgrading from RW5.3.1 to RW7
I am currently running RW5.3.1 on an old MacBook running Mac OS 10.11. Because of the age of the laptop I cannot upgrade the OS but RW 8 needs 10.12 or newer. I can’t find where I can go to upgrade to RW7 as several stacks I have bought recently won’t work using RW5.3.1. Can anyone help?
You can buy RW 7 on the MacStore for 43,99€
But you need at-least OS X 10.11 so you should be good to go
https://itunes.apple.com/de/app/rapidweaver-7/id1152495189?mt=12
From this page you can download all versions of RW: https://www.realmacsoftware.com/rapidweaver/releasenotes/
On this page you can find instructions on how to upgrade from older versions: https://help.realmacsoftware.com/rapidweaver-7/upgrading-from-rapidweaver-5-or-6
Thanks so much
