Poster
blah blah blah
I don’t have 400+ images, maybe 100, the rest of the files are php and more…
It’s Poster Stack by @instacks and I don’t have archives turned on. I don’t want dates associated with my posts, and I decided to use only tags, not categories.
The included blog plugin is going to behave totally different than something like poster stack or armadillo will.
Yes, of course, Doug. Armadillo is a totally different animal, as it does not live in your RW file. My point is… warehousing is not uploading my images as they would be by drag and drop/resourcing, and Poster is great as it’s compact and light on the republishing. It’s been quite some time since I’ve used the RW blog.
I understand what you are saying @LSPhoto, but this was not the point of my post. My point and @teefers point is that there is that something isn’t working properly with RW built-in blog as it uploads tons of files for every change… This forum is littered with comments about this, there is definitely something not working properly with RW’s core functionality, which is what I am using.
OK. @wvillers are you warehousing? Never heard back on that one.
No warehousing, read my previous posts: out of the 400+ files uploaded after a mere change, only 5% might be images…
ok. gotcha. Maybe try Poster instead?
Poster looks really nice, I see why you would recommend it… I’m concerned over redoing 6 years of news/blog posts and spend $50 though…
I love it for the control of a stack. I can see how it would be time consuming to do this. I myself am redoing what I have with new images… but the price… worth it to me.
Oh… you haven’t found the little “convert” button yet? … just kidding
I recently converted my 600+ page blog using the macro program “Keyboard Maestro” - I automated the copying and pasting of all into from the blog page to a stacks “template” page." It actually went pretty quickly once I got my macro’s setup and working.
I’ll give it a shot… The blog looks much better with this Poster thing, I’ll check Maestro to see if it makes it less painful… Or we just might get an intern
Jannis, the developer at @instacks is a regular here and a lot of us are using it, so feel free to post questions
oh, and make sure you use warehousing.
A warning… If you not used to setting up macro’s it can be rough to learn on something as tedious as this. But it would certainly train you very well on how to use macro’s to automate some takes. I use KM for many “every day” repetitive tasks.
What do you mean by warehousing images? Thanks.
Warehousing is when you host your image on your server (or another host) and point to it via full url (path) in RW. Usually you ftp your image up to an “images” folder or similar. This is done instead of dropping the image into RW. This keeps project files smaller as the image is not in the project but on the server. You can also “call” the same image over and over from many pages.
Thanks! Not sure I know how to do that - set up an images folder on my hosting site (not computer) and then instead of the photo being dropped into RW, I type in the path pointing to the folder, then the image name?
/imagesfolder/pictureofdog
let’s say? I’ll have to look up how to do that.
Anyway, thanks for the tip.
Check out this free ebook, it’s a step by step guide:
I’m noticing this republish all files issue a lot. RW 7.5.2. Make a small change, all files publish. It’s not a new problem, but it is annoying.
