Cartloom 4 - E Commerce for RapidWeaver
Ok. Thanks. That’s a very useful feature to diversify the product offerings (especially for more expensive items). Too bad now it is available only for Plus or Pro Plans :slight_smile:
Also, if you don’t mind me suggesting a new feature…what about best offer/make an offer (something slightly different than name your price feature", I mean…).
Thank you for all of your efforts!
@nickcates Quick question. is Cartloom White Label - Can I use it / resell it to my clients with me paying the fees and billing my clients?
You mention a feature for “best offer/make an offer”, but this is exactly what catalog mode can be used for. Instead of an “add to cart” button, you could have the purchase text read “Make an offer”, and when clicked buyers are prompted to send you a email with there offer :slight_smile:
Generally speaking yes. The entire customer experience can have Cartloom branding removed, and seller branding added. Keep in mind though, the Cartloom seller admin will always be branded, but if the seller is your client - and you control that, then in theory they’d never see our branding. Please let me know if you have any questions on this.
Hello,
I wonder if you can help me with the “Addthis” Add-on. I am trying to insert the social icons between the “add to cart” and “Contact/Ask a question” tabs, in correspondence to the “Share” line, but to no avail. The social icons appear at the bottom of the page instead. I am using the Fortress Theme. Any ideas? Thank you for all of your time and efforts.
Social icons at the bottom of the page, could you send me a link to view this happing? Also make sure to have “AddThis” correct setup in the Addons area in your Cartloom admin panel. Hope this answer helps.
Hi Nick,
Please find attached two screenshots of my project. Hope you can help me. Thanks!
Gotcha, so all Cartloom settings are isolated from RapidWeaver. For the correct AddThis settings go Cartloom Admin > Addons > AddThis.
Then you can also remove the AddThis RapidWeaver code.
Hi Nick,
Thank you for your reply.
This is what I did:
1- I went to the Cartloom Admin> Addons> Addthis
2- I enabled the Add-on and included my profile ID
3- I went to Addthis Dashboard and created an Inline share Button.
4- I copied the Addthis Html codes and pasted them into my Body section of my Rapidweaver theme.
5- The social icons appear at the bottom of the page, as in the screenshots ( on the right side of the screenshots you can see where I pasted the codes).
Is there something I am not getting? In which of the above passages I am doing something wrong?
Thank you for your patience!
Is anybody using Cartloom 4 in Germany and knows if this is compliant to the german law? This requires a dedicated position of the Buy Now button, the legal texts it has to show, etc…
Thank you
Jan Fuellemann
Jan,
Please contact our support department for support. Thanks.
Step 4 is not nessesary, and should be removed, all AddThis setup for Cartloom must stay completely within the Cartloom admin panel. I believe the confusion is in AddThis having two different things labeled a "Profile ID. I’ve attached a screenshot of the correct Profile ID you want, it’s going to look like a random string of numbers and letters.
Thanks for your help, Nick. Works perfectly now.
It is more like a pre-sales question, but I do, thank you!
Awesome! I was having the exact same issue myself when first trying to get setup, LOL!
Hi All
Could someone please let me know if product variations have maximun amounts in ‘Cartloom 4’ and what they are? Need to have products with 50!+ variables.
Thank you in advance
All the Best
Damian
