Not sure what happened but my home page formatting is all mess up! The page tabs appear are now blue links, my home page banner image is gone, and all other photos are “blue ?”. Everything is messed up.
The only thing I can think of is I installed the pdf stack on a dif. page-- would that mess up the home page?
Is there a way to “reset” or replace the home page?
Total novice so explain it like you are talking to your grandma
Thank you
Live it shows correct but on RW 8 Home page it is a mess. I’m afraid if I hit republish it will wreck the live version but there are changes that need to be made.
All of my time machine backups are messed up too- but they were fine before. It appears to be something wrong in the RW 8 file.
Please help!
url Kurukula.org
The only thing I can think of is I installed the pdf stack on a dif. page-- would that mess up the home page? [/quote]
That might be a good place to start (undo the last thing you did) but work on a copy of your project, not the original since you seem to be worried about losing your work. Leave the original untouched even if it’s “bad”.
In fact, I make a “backup(copy)” everytime I make a change so if something goes terribly wrong, I can easily return to the original.
Because i’ve had similar problems. It’s not just novice problem
Although I probably am one.
