In the beggining when I switch from RW5 to RW6, my whole site was a mess; I had to rebuild almost everything. If I switch now to RW 6+ will it be the same thing? What benefits I had if switch? Thanks in advance, as always.
I had the same experience as you, when I switched from RW5 to RW6. Fortunately, I had only one project to redo from scratch.
The benefits? I guess the main one is the upcoming Stacks3 pluginā¦
Thanks Rovertek.
Same here, my site is humongous. Had any problems with your stacks in the transition?
Printery
Sunny Puerto Rico
If youāre having issues in the migration, please let us know (and send us a copy of your project file): support@realmacsoftware.com Iāve been looking into a project that should have shown this issue this afternoon, but the RW5 project was displaying the same (albeit incorrectly) in RW5 and RW6.
āN
Thanks Nikf,
I did have problems with migration a year ago, I never switch to RW6. Now I have to do it. Just want to know if the old transfer rules still or there have been new changes. I have not decide if I get a new theme or stick with the same one, new ones are more flexible. Any advice?
Printery
Sunny Puerto Rico
@Printery
Have you tried this?
First, open and save the RW 5 file with RW 5.4/5.41 (not with RW 5.3.2)
Then you can open/importe the RW 5 file with RW 6.
Otherwise, you will lose some content.
Gracias Oscar.
I give it a try and let you know. Any problems with the stacks?
Printery
Sunny Puerto Rico
Please make sure to update all your stacks and plugins. If youāre still having problems, email support@realmacsoftware.com with your Rapidweaver version, your OS version and a list of stacks/plugins you have been using so the problem can be solved easier.
Just a quick note about the upgrade flow. We made significant changes a while back to make it easier: the guide has been updated to account for those changes:
http://realmacsoftware.com/rapidweaver/upgrade
āN
Thanks Guru I will start with you recommendations and keep you posted.
Printery
Sunny Puerto Rico
Great guide, thanks Nik! But: why do you still link to RW5.4, when thereās already 5.4.1 available? This disturbs the upgrade flow for the user, since heās confronted with the update suggestion for 5.4.1 when starting 5.4. And since thereās no information about this step in the guide, the user could get (unnecessarily) confused. So what about directly pointing the download to RW5.4.1ā¦?
Hi Matthias: good spot. All fixed up now
Iām nearly ready to take the plunge but I wonder what awaits me. The upgrade guide says that āideallyā I should be running Mavericks or greater to upgrade to 5.4.1. Iām running 10.7.5.
Is it going to cause me problems?
Rob
While it wonāt typically cause problems, we recommend that you launch RW 5.4.1 and RW6 on the same machine. As RapidWeaver 6 requires OS X Mavericks, we recommend you use the same OS for the initial migration.
āN
For reasons I wonāt bore you with thatās not possible. Instead Iāve got an old late 2008 Macbook running 10.7.5 and RW 5.3.2. Itās this set up that Iām planning to update to 5.4.1.
I have a second, newer machine with RW6 on.
My plan is to move sites one at a time as they need updating from machine to the other.
I understand thereāll be some - probably plenty - of manual adjustments that Iāll need to make but this is the way Iām planning to do it.
If you can foresee any problems, Iād appreciate a heads up. Iām planning to start on Monday.
Rob
I canāt envisage any problems⦠one thing I would note is that you must run RapidWeaver 6 on your newer Mac to ensure the appropriate app support folders are created before you try and copy addons to RapidWeaver 6. Manually creating the ~/Library/Containers/com.realmacsoftware.rapidweaver6/ folder will cause untold amounts of pain - OS X creates this folder on first-launch of the app, and ties it to RapidWeaverās digital signature.
In light of that, if you have a RW5 application support folder on your older Mac, maybe copy that to the RapidWeaver 5 location on your new Mac, and RapidWeaver will then migrate it for you.
āN
Iāve got RW6 running on the new machine already. Iāve used it to build two sites. Iām going to do the migration āby handā as it were, taking over stacks and plugins as theyāre used by my sites and using it as an opportunity to lighten some sites that - for example- use the Nivo slider plugin and PlusKit and replacing it with a stack-based slider and Houdini.
The main thing Iām concerned about is that everythingās not going to go BANG when I run RW5.4.1 on OSX 10.7.5. Iām going to be working with live sites used by real people.
The rest of the migration is down to me.
If youāre at all concerned, you can of course open duplicates of the project with 5.4.1. There shouldnāt be any problems, but thatās obviously an option if youāre fretting.
āN
Fretting? Can you tell?
Trying to upgrade to RW 6 and older RW5 sites. Issue is, RW 5.4.1 wonāt open in OS X 10.10 ⦠so now what do I do?
